Re: 458e shuts down during job
I'm co-signing the co-sign, check if there are other devices on the same circuit that could be drawing enough to dip the overall power below what the copier needs. Things with pumps or motors that kick on periodically could be causing overdraw (fridges, freezers, air compressors etc)
Could also just be an actual fault on any high draw components too, the whole situation screams 'not enough juice'
Edit> Sorry missed that you said you checked the counter... although the fact that it's not completely shutting off could be why it's not being added to the counter.
