Bizhub 300i , code E305
  • pinspin
    • Oct 2011
    • 156
    [Error Code] Bizhub 300i , code E305
    Hello . The copier shows the E305 code, it does not interfere with the work. How do I cancel a message? We will be grateful for any help. Thanks.
  • tsbservice
    Field tech
    • 8010
    Re: Bizhub 300i , code E305
    Looks like MAC address mismatch. MFP board changed?
    • pinspin
      • Oct 2011
      • 156
      No, HDD has been replaced
      • Synthohol
        Certified Konica Expert
        • 5823
        back up the info to usb and format the drive?
        • pinspin
          • Oct 2011
          • 156
          didn't back up ,disk formatted
          • tsbservice
            Field tech
            • 8010
            I'm sure there was procedure on MKM tech site how to proceed. Don't have access anymore will dig into saved info Monday if nobody has is.
            • Synthohol
              • 5823
              i hope you can get access to LMS server.
              maybe disable the marketplace?
              • tsbservice
                Field tech
                • 8010
                Hey Synt Thanks for backing me up on this topic.
