Missing Button - [Web Browser Setting]
  • ndlovu
    • Nov 2013
    • 21
    [Misc] Missing Button - [Web Browser Setting]
    Quick question and that is the under [Utility] - [Administrator Settings] - [Network Settings] - [Web Browser Setting] the C454e that I am working on does not have the button. The memory upgrade is added and it have the web browser firmware loaded, but the button is not there to enable the web browser.
  • Bix
    • Apr 2018
    • 1421
    Re: Missing Button - [Web Browser Setting]
    Have you changed the dipsw for firmware version?
    • copier tech
      • 8130
      Do you have the LK-101 option installed?
      โ€‹
      • ndlovu
        • Nov 2013
        • 21
        I have not changed the dipsw and where would I find it. I did try setting the software switch #150 but that did not do anything.
        • ndlovu
          • Nov 2013
          • 21
          The firmware that I installed is the latest with the web browser and I am thinking that it installed. I know that I have not setup the license etc. but other that we have don't have the license but have the web browser button enabled.
          • tsbservice
            Field tech
            • 7957
            The optional Upgrade Kit UK-204 and i-Option LK-101 v3 are required to use the Web browser function on this machine.
            • ndlovu
              • Nov 2013
              • 21
              I have installed the UK-204 and the firmware that I installed is (G20-K6_LK-101). How do I install the LK-101 v3? Sorry new to this Web Browser feature. I have done the following except for the "license" activation (To use web browser function, set switch No.150 to [00000001] at Bit assignment/[01] at HEX assignment in [Service Mode] ->
              [System 2] -> [Software Switch Setting],then activate the i-Option license(LK-101 v3).).
