firmawre compatibility between minolta and olivetti?
  • tecnodue
    • Oct 2020
    • 7
    Does anybody knows if i can update a bizhub c220 with the firmware of olivetti d-color c220?
  • Toxic
    • 697
    Re: firmawre compatibility between minolta and olivetti?
    No.
    Why do you even want to do that?
    • tsbservice
      Field tech
      • 7983
      As side note. On newer Develops I was told KM FW will just fit. But that's other brand and model.
      • tecnodue
        • Oct 2020
        • 7
        Originally posted by Toxic
        No.
        I can't find minolta firmware for c220.
          • 14551
          I'm not sure if this will help, but I used to get Oce machines and change soft switch 10 to hex 02 and that would make it boot as a KonMin machine. As for firmware, I was able to load KonMin firmware after the soft switch change. I never tried loading firmware before the change so it may have worked before as well.
          I am not telling you that it will work for you, but I did have success in the past.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            I only use correct firmware but I do know guys that use Develop & olliveti firmware in Konica's they say it works
            Regards Mark
            • tsbservice
              Field tech
              • 7983
              I believe that's true. However it's not recommended as other functions and features may be affected inadvertently.
              • Max
                • Oct 2011
                • 555
                Yes you can. I do it practically every day. However only from mf222 c224 and upwards. Worst case the firmware won't be written or simply won't take the USB.
                • copier tech
                  • 8131
                  Yes you can, I have a few Olivetti models & simply use the Konica Minolta firmware as normal.
                  • rolls.bo
                    • Sep 2014
                    • 42
                    Firmware is the same for all brands but the model must be the same. Never change the soft switch 10, because the certificate settings change
                    • rrrohan
                      • Sep 2011
                      • 1976
                      prob easier to just ask for someone to give you the correct firmware
                      • copier tech
                        • 8131
                        The Olivetti & Konica Minolta firmware are both identical so that would be pointless.
                        • rolls.bo
                          • Sep 2014
                          • 42
                          good you wrote right .......... he is the same firmware
                          • occus
                            • 332
                            It works not always.
                            I had a Develop ineo+454e (bizhub c454e) which the new firmware did not accept.... every time it boots to normal copy ready state.
                            Only afterwards did I see that only the Konicaminiolta models were listed in the aditional .txt in knova.
                            Firmware updates from konicaminolta are always a bit faster then those from the other brands like Olivetti / Develop.
                            That means it is not always compatible. But i think the sw switch 10 is the solution.
