Bizhub c3110 " INITIALIZING total memory 1024MB"
+ More Options
Posts
  • Proffice
    • Oct 2019
    • 11
    Hello, I need your help guys.
    After powering on a customer's bizhub c3110, display freezes with message " INITIALIZING total memory 1024MB"
    Machine irresponsive to any button. I changed the memory board(WW) A6DTR70333 and i tried to update the firmware (as Konica told us), but the problem can't be solved because i can't get to service mode (the machine still does not respond to any button).
    Calibration during startup come through, fuser unit is hot and after opening and closing any cover machine rotates.
    Any thoughts?
    Thank you in advance
  • tsbservice
    Field tech
    • 8062
    Re: Bizhub c3110 " INITIALIZING total memory 1024MB"
    Check out this thread, most likely faulty SSDB.
    Ineo+ 3110 (Bizhub C3110)
    • tech51
      • 846
      If you tried the ssd board and it’s still the same you will probably have to replace the mfp board.
      I had one like this just a couple of weeks ago and the mfp board was the cure.
      Also happens on the C3100p FYI.
      • copier tech
        • 8215
        Any thoughts?
        There is a special firmware for this exact issue.
        Fit the original boards back & update with the restoration tool.
        bizhubC3100P_C3110_Procedure_of_Restoration_Tool.pdf
        • tech51
          • 846
          [ATTACH]46992[/ATTACH]
          • copier tech
            • 8215
            100% worth a try before replacing expensive boards!
            • waski.th
              Hello
              I have the same problem. I need NvramClearToolVer101.exe . I can't see it in the infohub. Can you help me?
              • copier tech
                • 8215
                Originally posted by waski.th
                Hello
                It is on InfoHub I looked earlier.
                • Tiagocang
                  • Feb 2022
                  • 62
                  hello im trying to search for that on knova and not find it... only find A6dr30G0304-999 fw is that?
                  • copier tech
                    • 8215
                    Happy to supply this if needed.
                    Printer & Copier Firmware - www.printerfirmware.co.uk.
                    • Tiagocang
                      • Feb 2022
                      • 62
                      thanks but my question is i can get this from infohub? NvramClearToolVer101.exe? i had some machines with this error and wanna try that before replace ssdb
                      • copier tech
                        • 8215
                        Yes it will be on InfoHub.
                        • Tiagocang
                          • Feb 2022
                          • 62
                          dammit cant find it in the search bar what do u search?
                          • copier tech
                            • 8215
                            • Tiagocang
                              • Feb 2022
                              • 62
                              [ATTACH=CONFIG]52553[/ATTACH]
                              thanks for the help but i tbh dont know what im doing wrong but problably that tool dont exist more on knova i search for Initial Published Date and never appears that tool for DownloadnoResTool.jpg
