Bizhub c280 printing out of paper
  • Adeboy
    • Sep 2020
    • 9
    I ve changed the door and fuser unit of bizhub c280 but the problem persist. It prints out of paper. A lot have been done to no avail. I discovered that if I use hand to support the paper inside the bypass tray, it may print on paper correctly. Has anyone encountered this b4?
  • copier tech
    • 8138
    Re: Bizhub c280 printing out of paper
    What is the exact fault "It prints out of paper?" What does this mean, you have a "load paper" message when using the bypass?
    • tsbservice
      Field tech
      • 8005
      I will wild guess he means registration is off cuz registration clutch is faulty.
      OP samples please and it could be only of your benefit if you posted in right forum:
      https://www.copytechnet.com/forums/konica-minolta/
      • Adeboy
        • Sep 2020
        • 9
        Yeah, the registration is off. The printer prints when the transfer belt has moved on b4 getting to the paper.
        • copier tech
          • 8138
          Any P codes?
