Bizhub 283 jamming all the time
  • bgolpmp
    • Jun 2015
    • 27
    Good evening
    I have a bizhub 283 that keeps jamming when I am trying to run some 80lb card stock. I have to do some 2 sided prints. I volunteer some printing for a non profit and hate to have them send this out and pay to have it done. It is always getting stuck in spot #1. I can't seem to change the settings to Thick paper because I need double sided prints. Any other thoughts???
    Andy
  • femaster
    • May 2011
    • 1519
    Re: Bizhub 283 jamming all the time
    Originally posted by bgolpmp
    Good evening
    Andy
    If you are running 80lb card stock, you will need to run it through the bypass tray, on the thickest setting there is, and you will need to do manual duplexing (double sided). According to the specification sheet, the copier isn't designed to run anything higher than "55.75lb" paper, even through the bypass. There is no way you will ever get it to (nor is it designed to) duplex 80lb card stock.
    • tsbservice
      Field tech
      • 8052
      Are you sure that "55.75lb" paper is maximum through bypass feed. In spec sheet it says max is 210gsm which practicality is equal to 80lb. Of course it should be manually duplexed.
      • femaster
        • May 2011
        • 1519
        I thought it was extremely strange as well, but according to the specification Sheet for the Bizhub 283, it states 16lb to 55.75lb (60-210g/m2). If 210 is close to 80lb, maybe it was a typo on the spec sheet? Screen capture attached.
        • tsbservice
          Field tech
          • 8052
          [ATTACH=CONFIG]47098[/ATTACH]
          Honestly I dunno. Sounds like they miscalculated.
          I used this calculator.
          LBS to GSM
