Best compatible toners
  • barber782
    • Aug 2011
    • 286
    Hi everyone,
    has anyone got a preferred compatible toner they use for Konica machines, mainly c258, 458, 250i etc?
  • tsbservice
    Field tech
    • 8067
    Re: Best compatible toners
    Why? This is like shooting in your leg long therm wisely.
    • copier tech
      • 8222
      Originally posted by barber782
      Hi everyone,
      Never yet found a good compatible toner they all cause some sort of issue.
      Simply not worth it shortening the life of your drums, devs & transfer units costs more in the long run.
      The main reason is because genuine KM toner has a small % of developer in with the toner keeping the devs topped up.
      • CWP
        • Jun 2013
        • 168
        We have found the the best compatible toner is OEM and we have found it to be 100% compatible for the machine it was intended.
        • Bix
          • Apr 2018
          • 1421
          I had a stingy customer who bought a very old printer. I believe it was a C280. This printer was sold out, almost given away, but it always worked. For only $ 100. After the customer ran out of toners, he inserted compatible toners. Now he has incalculable damage and he preferred to throw the printer away. We also used compatible toners...it's a nice saving... but after several months the savings became a kick on the teeth
          • Toxic
            • 698
            For BW machine type you can try some compatible toners,i see all the time users put them in all sort of machines and it works much or less ok, some toners make problems quickly and some of them run as OEM.
            It is a bit lottery.
            But for color machines is other story, have seen everything ruined many times, drums,developing units,TCR errors...
              • 16528
              Here are a few companies that I recommend:
              - Static Control
              - Media Science
              - Katun
              I had a company from China send me some free samples for a Kyocrea 3551ci. I have test copiers that we use for nothing but testing out compatibles. We compare the results with Original OEMs'. I'm looking at the test pages side-by-side...I literally cannot tell them apart.
              I refilled the carts myself and replaced with new chip.
              Cost:
              Chip: 75-cents
              Toner: $21.00
              Total cost: $21.75
              • avecosat
                • Jun 2012
                • 305
                Katun is the best but only for a special occasions .
                • tsbservice
                  Field tech
                  • 8067
                  - Static Control
                  - Media Science
                  - Katun
                  Cost:
                  Chip: 75-cents
                  Toner: $21.00
                  Total cost: $21.75
                  I'm sure you know short therm calculations may result in long therm interesting findings.
                  The tests should be run over and over like for months and gong full PM cycle at minimum.
                  Here there are plenty of volunteers I know to test how compatible works on KonMin still haven't heard good ones for color machine.
                    • 16528
                    After I sold my Kyocera dealership years ago, I had to sign a no-compete clause, so I went into the compatible toner cartridge business. We rebuilt and sold thousands and thousands of compatibles over the years. Everything from HP, Dell, Lexmark, ect.
                    I'd say I know about as much as anyone about compatibles. I agree with you that testing is paramount. I don't take anyone's word for it....good or bad. I do the testing.
                    On a side note: I'm not trying to change anyone's mind. I'm just giving y'all my experience based on the results I have gotten.
                    I don't know if anyone has ever seen a bottle of color HP toner. It's a powder but if you shake it up in the bottle, it looks like a liquid. HP has gotten the toner participles so small that it looks like water.
                    EDIT: Some government accounts won't use anything but compatibles due to "saving the environment".
                    • blazebusiness
                      SanDiegoCopierRepair.com
                      • 1257
                      Hi everyone,
                      The Konica toners are not just toner but also have developer as a component. The generics do not. For that reason you should always use the oem. It maintains the developer to toner ratio correctly. Otherwise you run the risk of ddvelopers getting starved and failing early. Not worth the risk in my opinion. Any savings you get from the compatible toner evaporates with more frequent parts needed.
                        • 16528
                        I remember back in the day, Sharp came out with a copier that (supposedly) never required changing the developer because every new toner had the developer in it.
                        • blazebusiness
                          • 1257
                            • 16528
                            I think I remember reading somewhere that Kyocera put fine particles of "ceramic" in their toner. It's supposed to help clean the drum or something.
                            Hence the name: Kyo (Kyoto Japan) cera (ceramics). Kyocera.
                            • tsbservice
                              Field tech
                              • 8067
                              Long before they even heard about photocopiers they were Kyoto Ceramic Company.
                              Our Brand | About the Kyocera Group | About | KYOCERA
                              Kyocera - Wikipedia
