kmbs 658e
  • Kent
    • Feb 2018
    • 17
    [Error Code] kmbs 658e
    getting random C9401 codes, seeing in trouble history, other day scanner was disabled, turned off and on everything restored and works, the code is inconsistent, I see exposure lamp and CCD as possibilities
  • Max
    • Oct 2011
    • 559
    Re: kmbs 658e
    On previous generation it was the ccd and the cable plus latest firmware. Quite expensive. I would remove the ccd cable 1st and reform/stretch it. May just do the trick.
    • Woxner
      • Jul 2011
      • 849
      Re: kmbs 658e
      update firmware and replace home sw for scanner
