Does the 8 series transfer unit fit the 4 series
  • copier tech
    • 8202
    [Misc] Does the 8 series transfer unit fit the 4 series
    Quick question, does the C458 transfer unit fit the C554e?
    Different part number but from memory they look the same (I don't have 2 to compare)
  • drowranger
    • Jul 2015
    • 122
    Re: Does the 8 series transfer unit fit the 4 series
    HI yes it will fit to 4 and 6 series up to 55ppm.
    • copier tech
      • 8202
      Thanks, I have a ripped belt in a C554e but only have a new C458 belt unit.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        they are interchangable.
        If you swap over the top metal plate (use the new sep claw with the new belt) you can even fit the correct black plastic guide and its the perfect crime as it looks completely correct too.
        • MVPunisher
          • 209
          Good to know.
