C284e usb issue...
  • uullxx
    • Oct 2014
    • 5
    C284e usb issue...
    Hi everyone, I have a problem with a c284e.
    After executing memory clear, the machine no longer prints from USB.
    In the administrator settings I can only enable scan to USB, but there is no longer the print option ...
    Furthermore, after the memory clear, the machine does not even print PDFs from a PC that it previously printed without problems
    I installed A5C10Y0-F000-GDK-M1 firmware
    Thanks for your help
    Re: C284e usb issue...
    you wiped the memory... did you copy the config settings ?
    did you init the scan option?
    think of it this way... you just wiped your brain .. you need to put the memories back in.
    • emujo2
      • Mar 2017
      • 1579
      possibly you unset the HDD when you did the reset. many features are lost w/o the HDD. E
      • drowranger
        • Jul 2015
        • 122
        Please backup any addresses you added before enabling hdd. Easier to import them than adding them all over again ...
        • uullxx
          • Oct 2014
          • 5
          Thanks everyone for the answers.
          I imported the backup of the settings and now the machine prints from the usb memory.
          However, it does not print some PDFs from a PC: the blue LEDs flash while receiving data but it does not print anything. Other jpg files, doc, emails are printed regularly ...
          Hard Disk is enabled.
          • uullxx
            • Oct 2014
            • 5
            I double-checked everything from the beginning and realized that the hard drive was disabled.
            I don't understand how this could have happened ...
            I have enabled it again and now the machine is fully functional.
            I thank everyone for their help
              • 23009
              Unfurtunately this has happened on quite a few different models of Konica Minolta. The HDD becomes UnSet ... nobody knows why. Just set the HDD to Set, format, then reloading movie data restores function. =^..^=
