C284 C-2152
  • copiertec
    • Jan 2016
    • 2205
    C284 C-2152
    Machine had a squeak, so I opened the right side jam door and cheated the door switch, ran a few on off cycles now the machine has a C2152 error. I have pulled out the transfer unit made sure sensors were clean, removed the fuser and reseated, reseated the transfer belt, but still have the code. What did I screw up? Any suggestions would be appreciated and thank you in advance.
  • tsbservice
    Field tech
    • 8007
    Re: C284 C-2152
    Didn't have this one but may worth check this ICP:
    bizhub C224 has C2152 error code
    • tech51
      • 846
      • copiertec
        • Jan 2016
        • 2205
        Re: C284 C-2152
        Thank you for asking, tech51, that may have resolved the issue. I opened the door to turn the gear on the waste toner box, closed it and the code was gone. It had me going for a while, I pulled out the transfer multiple times, cleaned the ID sensors, pulled out the fuser unit, checked all the gears on the trans belt and fuser, etc. was ready to throw in the towel, checked the waste toner box, closed the front cover and it came to ready.
        If it's not obvious...I am not a seasoned Konica tech, but I catch on real quick when pushed into the fire, I have made made note.
          • 23006
          Re: C284 C-2152
          For future reference, you can get this code when toner blows up onto the inner frame, covering the sensor for the color primary transfer shift mechanism. This can occur at the same time as the primary transfer waste backing up. =^..^=
          • copiertec
            • Jan 2016
            • 2205
            Re: C284 C-2152
            Thank you, blackcat. I did empty (Vacuum) the waste toner collector on the transfer belt unit when I had it out the fourth or fifth time and vacuumed the id sensors at the same time, so maybe that was an issue as well. It boils down to having done this for many of years, just not a lot of Konicas, and a little luck and some good help from Copytechnet.
              • 23006
              Re: C284 C-2152
              The photo is too large to load, but the sensor is dead center in the middle of the rear transfer unit rail, and it doesn't look like a photointerrupter at all.
              Ok, it's really small, but maybe you can see it. =^..^=
              • copiertec
                • Jan 2016
                • 2205
                Re: C284 C-2152
                [ATTACH=CONFIG]47149[/ATTACH]
                Thank you, I did take my vacuum and brush along that area you have mentioned as I am almost obsessive about having a clean contacts and sensors, so almost unknowingly, I am sure I vacuumed this area because I remember the sliding lever by it.
                  • 23006
                  Re: C284 C-2152
                  Being obsessive has it's benefits. I would know. =^..^=
                  • copiertec
                    • Jan 2016
                    • 2205
                    Re: C284 C-2152
                    I'd give you two thumbs up if I could.
                    • tsbservice
                      Field tech
                      • 8007
                      Re: C284 C-2152
                      Yes, but in fact it is
                      Yet another picture of PS39.
                      • MVPunisher
                        • 209
                        Re: C284 C-2152
                        Yep that is a rank B code so even if you fixed it, it will not reset without a open/close of front door.
                        • Bix
                          • Apr 2018
                          • 1421
                          Re: C284 C-2152
                          You may need to troubleshoot with the clear key
