Anyone else getting crystallized/hardened toners from KM
  • SAR
    • Jul 2009
    • 182
    We've had several bad oem Konica Minolta toners in the last 2 months or so and was just wondering if anyone else is seeing this.
    We have a climate controlled warehouse and have never had issues in the past with supplies, so I figured I would check to see if anyone else has had issues, because I don't think it's on our end unless it could be the shipper storing them in a hot or damp area.
  • copier tech
    • 7931
    Re: Anyone else getting crystallized/hardened toners from KM
    What exactly is wrong with them to make you feel they were "bad" ?
    • SAR
      • Jul 2009
      • 182
      The toner in the cartridge is hardened. If you shake the cartridge it sounds like there are marbles in there.
      We have had to replace some toner hopper and development units because of it.
        • 35061
        Please explain exact what you mean by "OEM." Usually that is a term used by those who do not want to admit they are using after market products. The problem you describe is one of the reasons to only purchase KM toner from KM.
        • and
          • Oct 2011
          • 88
          One time about a year ago. Bizhub 554e
          • SAR
            • Jul 2009
            • 182
            These are genuine Konica Minolta toners. We are an authorized dealer and NEVER use non oem toner, that is a recipe for disaster.
            • tsbservice
              Field tech
              • 7635
              This will happen when toner is stored or exposed to high temperature, obviously before entering your storage area. I would claim them all.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Correct just send back to Konica
                Regards Mark
                • occus
                  • 312
                  [ATTACH=CONFIG]47152[/ATTACH]
                  Same... one time one bottle since 10 years. Maybe 2 years ago.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2142
                    • Bix
                      • Apr 2018
                      • 1421
                      In the 8e series we had a whole lot of bad toners. Konica Minolta was aware of the problem and they proceeded with the replacement. You give them the barcode
                      They knew about this problem
