BH-360/423, BH-C-280/C-360, searcable scan option.
  • Hansoon
    • Sep 2007
    • 3391
    Has anyone the set up instructions for the searchable scan option LK-105 for the BH-360/423 and BH-C-280/C-360 please?
    Hans
    • 23010
    Re: BH-360/423, BH-C-280/C-360, searcable scan option.
    I think this may be what you want. I went to the 5-day class on both those models, and this is the only document I have pertaining to that accessory. Check your email. =^..^=
    • Hansoon
      • Sep 2007
      • 3391
      Lots of thanks Cat.
      Anyone having for me the OCR-FW for these models please?
      Hans
        • 23010
        No updates on the original OCR Dictionary files. The C220 OCR Dictionary & 423 OCR Dictionary file have slightly different names, so they may be different. Check your email for links.
        • Hansoon
          • Sep 2007
          • 3391
          Cat, I do not use Google Drive and therefore have no account
          Hans
          • tsbservice
            Field tech
            • 8053
            Hans
            Hans, I think You need no account to download links to Google drive shared with you.
              • 23010
              Correct, just follow the link. =^..^=
              • Hansoon
                • Sep 2007
                • 3391
                Guys I know how to handle usually Google Drive, it worked before but not now. The Link "Next" brings me to a "Sign In" field. The same happens when I click in the received mail the link "xxxxx.exe"
                See attachments
                Hans
                EDIT: I just now dusted off my old, never used, laying in a dirty corner, Google Account but it also does not enable me to get the files. It tells me I have to wait for an Access Application.....
                Got the files in the mean time from "Down Under" lots of thanks to all of you guys.
                Hans
                • rrrohan
                  • Sep 2011
                  • 1977
                  • Hansoon
                    • Sep 2007
                    • 3391
                    Got'm thanks guys
                    Hans
                    • rrrohan
                      • Sep 2011
                      • 1977
                      the OCR sucks imo. better to use software OCR.
                      I normally hook up omni page, setup a watched folder for omni to monitor and process
                      • Hansoon
                        • Sep 2007
                        • 3391
                        Thanks, tried to use Omnipage years ago but I was not able to set up a hot folder. Too complex. What version of Omnipage would you prefer?
                        Hans
                        • emujo2
                          • Mar 2017
                          • 1579
                          rohan has a poimt..The older machines suffered when the OCR feature was in use, including network slowdowns..The 8 and newer seem to have resolved this. And for these machines you need the LK (hard copy license), memory upgrade, OCR file and firmware to support the LK system itself. Lot's of break points here..E
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Hans
                            google has some info setting up watched folders Watched folders – Folder watching jobs | Omnipage
