Konica Minolta C364 - cannot change function version of machine
  • Kenny
    • Jun 2009
    • 529
    Hi Guys,
    I am currently trying to change our Konica Minolta C364 from Function Version 3 to Function Version 7 to enable Airprint. When i try to change the software switch 25 hex 60 and try to select 'FIX' it doesnt save into the machine. I have updated the machine to the latest firmware, i can only change to Function Version to a lower version.
    Any suggestions would be appreciated.
  • robinsonad86
    • Aug 2014
    • 67
    Re: Konica Minolta C364 - cannot change function version of machine
    Its not the latest version of firmware you need. It is a special version up release which contains two lots of firmware and new movie data
    It's on Infohub -
    DLCSES_1514243EN
    • Synthohol
      Certified Konica Expert
      • 5849
      Air print Is unnecessary.
      If the copier and the wireless network are on the same subnet all the user has to do is be logged into the WiFi on their mobile device and they can print and scan with the konica app or sometimes it's just seen.
      All the firmwares and bit switches to trick the machine it thinkING it's an E series caused more issues than it fixed but ymmv.
      I believe the non e series are discontinued and no longer supported.
      it's a good day for a sales lead.
