KM 458e- Black box when scanning only
  • zackrch
    • Jan 2018
    • 8
    Hello, Has anyone ever had a problem when scanning there will be a black box in the middle of the paper?Using konica model B/W 458E.This is happen only if use for scan other than that nothing wrong.I have reconnect the ccd cable,prcb cable and all other cable that connect to the scanner unit and also i already upgrade latest firmware.
  • Zesti
    • Jun 2009
    • 308
    Re: KM 458e- Black box when scanning only
    What about copying????
    Scanning from ADF or Glass????
    • zackrch
      • Jan 2018
      • 8
      Scan using adf or glass same problem but copying is okay, my conclusion is the mfpb problem.
      • Bix
        • Apr 2018
        • 1421
        Why MFPB? I'd look for something wrong with the scanner first.
        • tsbservice
          Field tech
          • 8020
          Disconnect DF and remove dual scan board. Does it scan correct that way?
          • acusso1234
            Tecnico
            • Dec 2008
            • 250
            https://www.copytechnet.com/forums/k...ht=#post739264
            ... In the minute that you're thinking of giving up, think about why you lasted so long ...
            • allan
              RTFM!!
              • 5462
              So LEF on the glass and DF?
              Alway in the same position?
              Main scan line failure?
              Whatever
              • zackrch
                • Jan 2018
                • 8
                I guess mfpb problem because when I scan to the userbox and I zoom in on the machine there will be a picture like a damaged TV when i the zoom out it will disappear, if i print from the userbox all is fine.I changed ram/eMMcb and hdd already but no luck.
                • Zesti
                  • Jun 2009
                  • 308
                  [ATTACH=CONFIG]47325[/ATTACH]
                  Couldn't got it..... scan in user box showing pixels on preview but when print from box print is fine??????
                  • zackrch
                    • Jan 2018
                    • 8
                    Yes correct but my senior said change scanner board first if still same then proceed mfpb
                    • tsbservice
                      Field tech
                      • 8020
                      What's wrong about trying it without dual scan board?
                      • zackrch
                        • Jan 2018
                        • 8
                        What do you mean? If i take out the board how can i scan?
                        • Zesti
                          • Jun 2009
                          • 308
                          Scanner board is for dual scanner DADF only. But the problem is also showing from glass. Am I right???
                          • mearmi
                            • Oct 2010
                            • 350
                            tsbservice means
                            Disconnect the Document Feeder and Remove Dual Scan Board from the machine and scan from Platen Glass.
                            • tsbservice
                              Field tech
                              • 8020
                              You claimed problem from both glass and DF right? Without DF you still should be able to scan from glass.
