Bizhub pro C65HC error code c-2721
  • MAILSHOPGUY
    • Nov 2020
    • 3
    Need help with this one.
    Error code talks about High pressure unit 2 and separation pole. I have no idea where or what these are. And no luck for me finding them in the manual.
    First time posting so take it easy on me.Let me know if there is any more info you would need.
    • 22808
    Re: Bizhub pro C65HC error code c-2721
    page counts on service parts
    total page counts
    error code sheet PDF FORMAT
    what have you tried?
    genuine toners drums?
    Phil N. ' The Dentist '
    • MAILSHOPGUY
      • Nov 2020
      • 3
      4,100,00 total page count.
      using genuine toner and drums
      Haven't tried much because wasn't sure where to look.
      Thanks Phil
        • 22808
        using genuine toner and drums. Haven't tried much because wasn't sure where to look.
        Thanks Phil
        Sorry brother just noticed you are an end user.
        ok can you get us the counts on PM parts?
        error logs printed out and upload in PDF format
        this is a helpful page from the FAQ page for CTN:
        ALL FAQ pages here:
        Forum Rules: https://www.copytechnet.com/forums/misc.php?do=vsarules
        Donation Page: https://www.copytechnet.com/forums/v....php?do=donate
        A donation to CTN helps ONLY the site to remain functioning. It does NOT go to ANY tech the helps you.
        A donation will earn you a Contributor Badge like you see on my profile.
        That badge shows other users (esp the guys with manuals/files) that YOU have helped the site stay online, and they are more willing to help with requests for help.
        Welcome to CopyTechNet.com I know with the whole community pitching in we can get you back on the road to printing.
        Phil B. ' The Dentist '
          • 22702
          The only time I've seen this, a self-servicing customer forgot to plug in the separation comb:
          "C-2721" error.
          Separation voltage loss error. Separation comb spade connector is left unconnected during 2nd transfer roller installation. Heavy toner spray results, coating 1st transfer pressure HP sensor PS15.
          Remove imaging section to access PS15 on inner rear frame near white drive coupler. Clean PS15. Plug in separation comb spade connector.
            • 22808
            COPYSHOPGUY
            Meet BC he's da bomb when it comes to BizHubs
            Now Serving BC
            • MAILSHOPGUY
              • Nov 2020
              • 3
              "C-2721" error.
              Thank you BC. I was able to get the error to clear. I clean the plugs on the inside back wall. 2nd transfer roller I reversed after seeing to put concave end to back. Cleaned earth ground. and ran gamma adjustment.
              So far so good.
