Door won't close (Konica Bizhub C220)
  • Agathe
    • Nov 2020
    • 4
    [Misc] Door won't close (Konica Bizhub C220)
    Hello,
    I am coming to you today because I cannot print on my Bizhub C220 because of the error message saying the right door is not closed.
    I think it has something to do with the spring, but I am not sure so I don't want to break it more by forcing something that I am not supposed to.
    Here are some pictures of the door in question :
    What do you think ?
    Thank you in advance !
    Re: Door won't close (Konica Bizhub C220)
    Originally posted by Agathe
    Hello,
    [ATTACH=CONFIG]47312[/ATTACH]
    What do you think ?
    i think we need a bigger picture
    i think you should put this in the proper forum https://www.copytechnet.com/forums/konica-minolta/
    • Agathe
      • Nov 2020
      • 4
      Ok thank you for the advice and sorry for not posting at the proper place !
        • 22999
        That rings a bell for me. On this series of machines there's a top door over the fuser for removing jams. If that top door is not closed or the linkage gets damaged by slamming, the right door will not latch properly.
