Konica Minolta Bizhub 364 print only side only and I can't change the paper size
  • cristachecri
    • Mar 2015
    • 31
    Hello everyone . Please tell me if anyone has ever encountered this problem on Bizhub 364, namely: the copier copies and prints on one side only and I can't change the paper settings ... it's stuck in A4 format and I can't change in A3 e.g . The "change setting tray" button is gray and disabled. I encounter all these problems only in tray 1. Tray 2 works correctly. There is a solution please let me know. Thank you in advance
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: Konica Minolta Bizhub 364 print only side only and I can't change the paper size
    The trays/settings are locked. You need to turn off in admin or service mode.
    • cristachecri
      • Mar 2015
      • 31
      Thanks, but where do I have to do this ... I can't find this open-closed function anywhere
