Fs537 staple issue
  • tech51
    • 846
    [Misc] Fs537 staple issue
  • Firmaware
    • 30
    Re: Fs537 staple issue
    I had a similar Issue. It was the paper that cone out from thevfusing unit wavy.
    Gesendet von meinem SM-G980F mit Tapatalk
    • rrrohan
      • Sep 2011
      • 1976
      Have you clean/replace the finisher paddles above the eject assy
      Sent from my Pixel 4 XL using Tapatalk
      • tech51
        • 846
        Yes forgot to mention those.
        However as I said in my post the first set is ok, its the second set and on that has the problem.
        The only difference is that the first set goes straight through the fns and directly into the stapler whereas the first sheet for the subsequent sets reverses and is held in a guide where it waits for the second sheet to arrive then they are both exited to the stapler area and the rest of the set goes on top.
        I have a feeling that this is where the fault is but cant quite nail it down (yet).
        • rrrohan
          • Sep 2011
          • 1976
          So the alignment plates aren't squaring off paper or the paper doesn't sit back far enough in finisher?
          • allan
            RTFM!!
            • 5462
            Worth dropping the fuser temp to test the theory. Had similar issues with finisher stacking.
            If the paper is of a poor grade flip the ream upside down to see it that reduce paper curl.
            In that case get better paper.
            Whatever
            • tech51
              • 846
              • qbert69
                • Mar 2013
                • 1152
                Does this finisher have a reverse roller that tamps the sheets into place for stapling??? Or is it the side guides not tamping the sheets into position???[emoji848] It's also possible that there's either a bad stepper motor that is skipping steps or a problematic driver board missing steps--failing driver chip. Many times if a stepper is not driven at the proper current for a particular load, it can also skip steps!!!...which would probably indicate a bad driver chip.[emoji57]
                Sent from my SM-N950U1 using Tapatalk
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
                • Firmaware
                  • 30
                  I would hijacking the finischer door and looking inside during staple process to collect info
                  • tech51
                    • 846
                    • tsbservice
                      Field tech
                      • 7986
                      Indeed tough one. Only few pro-masters can catch such sort of problems. Thanks for following up with solution.
                      • Gift
                        • Mar 2011
                        • 2459
                        We just had a similar problem with badly aligned A3 paper in staple mode. It was basicly the first page that was "out of line".
                        We renewed the paddles, tried different paper, modified the paddles with longer ones - everything with no major success.
                        Finally we changed the angle of the paper exit tray with some washers between the 2 brackets on the tray assy and the machine and voila, problem was gone.
