Automatic reset bizhub 4050
  • Bot
    • Mar 2020
    • 8
    Hello, I have a problem with the 4050, namely the machine resets itself every 9-10 minutes, it does not display any message, no error after the post is reset. I uploaded the latest firmware, changed the setting of Power Saving and nothing helps, the problem occurs on several machines, please help
  • Bix
    • Apr 2018
    • 1421
    Re: Automatic reset bizhub 4050
    Hi, access the service menu and check the error list.
    • Bot
      • Mar 2020
      • 8
      The problem is she has no errors, it just resets without any message
      • tsbservice
        Field tech
        • 8020
        Unplug network cable, will it restart?
        • Bot
          • Mar 2020
          • 8
          It makes no difference whether it is connected or not
          • Phil_bizhub
            • Nov 2020
            • 10
            • Bot
              • Mar 2020
              • 8
              I wonder if it may not be a power supply failure...
              • and
                • Oct 2011
                • 96
                I see you have write "have tried with / without LAN cable" but i had a similar case with LAN cable and was the IPv6 of client enviroment.
                • allan
                  RTFM!!
                  • 5462
                  Leave a door open and check if is works for more than 15min.
                  Check the history for error codes even if it does not display it could still be logged if its a controller error.
                  Do you hear the relays on the power supply click on and off when it restarts. If that is the case its probably the power supply or even the fuser.
                  Or does it restart without the power supply loosing power?
                  Whatever
                  • tsbservice
                    Field tech
                    • 8020
                    Check the history for error codes even if it does not display it could still be logged it its a controller error.
                    Ditto on error history, some E301 may be logged. I would try HDD format at first.
                    • Phil_bizhub
                      • Nov 2020
                      • 10
                      does a relay have to click if the fault is in the power supply? The way I see it, the control unit has its own outlet on the PSU. Is it possible that this connection port z. B. has a defective capacitor or similar.
                      It already seems to be an absolute serial failure of the device? I noticed a comparative error with the corresponding Lexmark devices?
                      • allan
                        RTFM!!
                        • 5462
                        No not necessarily.
                        Whatever
                        • Bot
                          • Mar 2020
                          • 8
                          unfortunately the power supply did not help, I am looking for more
                          • Phil_bizhub
                            • Nov 2020
                            • 10
                            Oh , okay, thanks for the feedback, did you exchange it?
                            • Bot
                              • Mar 2020
                              • 8
                              yes i did. I also replaced the HDD, the problem is still there
