Bizhub C3851FS error C3201
  • Ihar
    • Nov 2020
    • 17
    I have the MFP Konica Minolta Bizhub C3851FS (it printed near ~30k pages) with error code C3201.
    Anybody know how to reset this error? (I don't know how to do trouble reset in this model)
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C3851FS error C3201
    Its a rank B error and will reset by opening and closing the front door or cycling the power.
    The fuser motor reports a locked state. Means its not turning.
    So the fuser is jamed on installed badly or the motor is shot.
    Could in the worst case be the control board.
    Whatever
    • Ihar
      • Nov 2020
      • 17
      I disassembled the fuser and found this:
      It isn't normal, I correctly understand?
      Is this part (orange or red strip) has some part number? Or I have to replace all Fusing Unit - A4Y5W22?
      • tsbservice
        Field tech
        • 8030
        [ATTACH=CONFIG]47470[/ATTACH]
        You cannot purchase separate parts for this fuser(atleast from KM).
        This looks like cleaning felt awfully damaged/destroyed. I guess although I wouldn't recommend you can try throw it out and see how it goes.
        Btw, good job doing this disassembly.
        • allan
          RTFM!!
          • 5462
          Get a new one.
          Whatever
          • Bix
            • Apr 2018
            • 1421
            This fuser only makes 105k pages.
            It's probably outlived his life.
            • Ihar
              • Nov 2020
              • 17
              Replacing the fuser unit A4Y5W22 solved the problem. But old fuser makes only 33k pages (not 105k).
