White spots
  • wynter17
    • Mar 2019
    • 33
    White spots
    Hello,i have this problem with my konica minolta c550,when i print something black it always has spots,the rest of the colors are working fine,is this repairable or not?because a new IU is pretty expensive,thanks!
    Sent from my SM-G980F using Tapatalk
  • Blizzoo
    • Aug 2013
    • 607
    Re: White spots
    To me looks like a 1st transfer issue. Your 1st transfer roller inside Transfer Belt may be worn out/dirty. Try swap the K 1st transfer roller with another color to identify if the problem moves with the roller.
    K 1st transfer roller tends to wear out much quicker than the other ones because is in a permanent contact with K drum.
    • wynter17
      • Mar 2019
      • 33
      Re: White spots
      Thanks! So i changed the first roller and the problem is still there,this is a full black image,i have a brand new black IU and that one is printing worse than this.
      • allan
        RTFM!!
        • 5462
        Re: White spots
        Not hijacking the threat.
        Hey thanks for starting this thread. I have a machine that is doing the same. Changed drum unit, dev unit and checked all the settings to be default. Its not a C550 but similar setup only a 958. Transfer belt is in good health secondary roller is not looking fresh but tested that. The B423 machines also did that. Been doing this for too long now and this problems solution still evades me.
        In its current application the machine does not print any solids only thin line tables so it does not show.
        Environmental issue could it be?
        Whatever
        • wynter17
          • Mar 2019
          • 33
          Re: White spots
          Hello! The first thing i was thinking is enviromental issues,my machine is in a cold enviroment during the night,so i believed it is moisture because of the pattern but why only the black drum?
          P.S. sorry for my english
          Edit: i added another photo with partial color
          • tmw
            • Dec 2013
            • 259
            Re: White spots
            Grounding issue ? Discharge lamp ? Just freethinking if they haven't been checked
            • tsbservice
              Field tech
              • 7975
              Re: White spots
              Allan, friend of mine showed me some time ago similar copy from bh958 and for him change of ITB unit solve this. But he's riding belt way past supposed life. Just a thought.
              • M94
                • Jul 2020
                • 158
                Re: White spots
                Is there a way to run these guys but with removing the charge step as an option? I'm not familiar with this model but with some you can disable charge at one place or another. Would result in a solid black page if the problem is charge related and the problem would remain if it's transfer\developer related. I'm still new to this but someone should be able to see this and re-state it in a way that makes sense.
                  Re: White spots
                  Since all the other colors are fine, I'd be looking at the K DV unit.
                  • Synthohol
                    Certified Konica Expert
                    • 5799
                    Re: White spots
                    Lol its a c550!
                    I'd be looking into buying a machine from this century lol
                    • wynter17
                      • Mar 2019
                      • 33
                      Re: White spots
                      I tried another itb,same result
                      • wynter17
                        • Mar 2019
                        • 33
                        Re: White spots
                        Originally posted by Synthohol
                        Lol its a c550!
                        It is from 2007 so i'm good haha
                        • Synthohol
                          • 5799
                          Re: White spots
                          Funny story from today.
                          Got sent to a Kyocera fax machine from 2005 with issues.
                          I fixed it by plugging the fax line into one of the 2 new 558e machines and turnd off the Kyocera.
                          They didn't know both the konicas have fax units.
                          Best call all year.
                          • wynter17
                            • Mar 2019
                            • 33
                            Re: White spots
                            Best call all year.
                            Haha,i can't count how many times customers forgot to plug in electronics,i get so angry [emoji23]
                            • afterhours
                              • Mar 2017
                              • 152
                              Re: White spots
                              What's the count on the black unit?
                              Sent from my SM-G981U using Tapatalk
                              Im a Loser Baby!!!
