C227
  • afterhours
    • Mar 2017
    • 152
    C227
    Hi everyone. I'm considering buying a C227 to sell but have heard rumors that it's not a good model. I'm familiar with the 4 series and 8 series but not the c227.
    Any thoughts you can share?
    Sent from my SM-G981U using Tapatalk
    Im a Loser Baby!!!
  • allan
    RTFM!!
    • 5462
    Re: C227
    Mechanically and functionally sound enough to pass. CMY are IU's and not drum and dev separate making the color IU's expensive. The black drum and dev is separately exchangeable and use developer replenishing.
    The change to contact charge rollers instead of corona charge lead to the drums and IU's not making it past the yield like the previous models. Also found that it does not quite keep up on toner feed for very high coverage.
    So good office color machine at its price point. Running cost on it is a bit high compared to the C308 .
    And not for a color print shop.
    Whatever
    • afterhours
      • Mar 2017
      • 152
      Re: C227
      Thank you thank you that is very helpful.
      Im a Loser Baby!!!
      • tsbservice
        Field tech
        • 8053
        Re: C227
        Yeah I don't like them especially compared to 8 series they seems like low cost alternative which they actually are. Still not bad overall, I hate small control panel, noisy duplex but in reality they will work. Have one b287(same engine without color IUs) close to 900k still running strong from PM to PM.
        • afterhours
          • Mar 2017
          • 152
          Re: C227
          Thank you. The whole idea of the drum and developer unit being together sold me on not purchasing it. The old 220s and 280s cost a fortune to replace the IUs
          Im a Loser Baby!!!
          • tsbservice
            Field tech
            • 8053
            Re: C227
            C220 series have separate drum units and dev units for all 4 of them unlike C227 series where all CMY are IUs.
            • afterhours
              • Mar 2017
              • 152
              Re: C227
              Sorry your right. I was working on a c220 when I sent that. I mean C203, c253, 353 etc.
              Im a Loser Baby!!!
              • spree
                • Jun 2012
                • 211
                Re: C227
                Please help,
                customer has Develop Ineo+ 227 (crossreference is Konica Minolta bizhub C227) and has message: replace imaging units: cyan, magenta, yellow, but when I check the maintenance count screen all maintenance is in good condition:
                Imaging units:
                (C) 29%, ends 12/25/2022
                (M) 29%, ends 12/25/2022
                (Y) 29%, ends 12/25/2022
                Developing unit:
                (K) 70%, ends 01/16/2033
                Drum unit:
                (K) 18%, ends 03/21/2022
                Fixing unit:
                64%, ends 11/04/2030
                Transfer roller:
                42%, ends 03/16/2025
                Transfer belt unit:
                27%, ends 04/23/2023
                What is wrong ? and why replace imaging units C, M, Y when they have 29% and ends 12/25/2022 ???
                Thank you.
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  Re: C227
                  Does the message actually say to replace them or to replace them soon? Big difference. If it says to replace soon, then the setting in the service mode for unit replacement is set to remind very early instead of normally. Can't remember the exact setting but something about pre-near life or something similar.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • copier tech
                    • 8200
                    Re: C227
                    Originally posted by spree
                    Please help,
                    Imaging units:
                    Developing unit:
                    Drum unit:
                    Fixing unit:
                    Transfer roller:
                    Transfer belt unit:
                    Thank you.
                    Bit strange but you can disable this warning with a firmware update & change a couple of SW settings in CE mode.
                    • spree
                      • Jun 2012
                      • 211
                      Re: C227
                      Thank you. I set there NO warning message. The message is still there but only in one raw. And the printing is continuos.
                      P.S. machine says replace them
                      • spree
                        • Jun 2012
                        • 211
                        Re: C227
                        Yesterday I have an idea when I made service at the machine. The machine had bad translation of the replacing the imaging unit. When was warning machine displayed it said "replace imaging units", but when was the warning message in row there where "replace soon imaging unit". Bad translation!
