bizhub 287 C6756 error code
  • jwai
    • May 2018
    • 502
    Hi everyone,
    One bizhub 287 the exposure don't light up when the machine has been turned on, the error code C6756 display.
    Check the connection of flat cable and it seems good.
    Any suggestions?
  • CP-1015
    • Nov 2020
    • 298
    Re: bizhub 287 C6756 error code
    CCD Power-supply voltage malfunction
    • jwai
      • May 2018
      • 502
      SO I need to replace the CCD unit ?
      • CP-1015
        • Nov 2020
        • 298
        Sorry, I'm not able to send a picture with the solution.
        • Synthohol
          Certified Konica Expert
          • 5735
          • allan
            RTFM!!
            • 5459
            Test for 5.1V and 24V on the respective pins as per the manual. PJ1 on CCDB to CN7 on the MFPB. Check on both ends or do continuity test on the harness. F8E on the MFPB is the only ICP that relates to the CCD unit i can find in the manual. So worth checking. Should be in the area surrounding the plug for CN7. If all the voltages are present grounding pin 16 LAMP_REM to pin 1 GND should turn the LED's on. If the LED's come on then MFPB does not switch it on for some reason. If the voltage are not present then DCPB not supplying it to the MFPB or there is a fault on the MFPB .
            The error does not mention the MFPB but i don't know how the power detection that triggers C-6756 work so cant rule anything out.
            Whatever
            • tsbservice
              Field tech
              • 7910
              Originally posted by Synthohol
              Why my manual isn't so detailed
              Lol, I didn't realize that quoted ONLY dots
              • allan
                RTFM!!
                • 5459
                Ok changed my mind about switching the lamp manually. Use a pull down resistor at first if you need to like a 1Kohm resistor to limit possible current.
                Disconnect wire for pin 16 going to MFPB first. That would be the right approach if testing that is meaningful. I would just do it by grounding pin16, bit that is me. Please keep the smoke inside.
                Found the trouble shooting in the manual a rough guideline to follow.
                Stuff is expensive and going there to change out parts one by one does not fly.
                Please let us know what you find.
                Whatever
