Crooked scan/copy - Konica C280
  • crisstian
    • Jun 2025
    [Misc] Crooked scan/copy - Konica C280
    Hello.
    I recently purchased a refurbished C280.
    I have a problem with scanning/copying, both in the ADF and on the glass.
    The image is crooked to the left at the bottom.
    I mention that I called someone and he adjusted the ADF, but he couldn't fix the problem.
    Printing is OK.
    I'm attaching a scan, hoping you can help me fix the problem.
    Thank you in advance!
  • allan
    RTFM!!
    • 5462
    Re: Crooked scan/copy - Konica C280
    The left front corner of the scanner bed tends to sag where there is no support.
    Pull up on that corner putting some back into it.
    Check if that makes an improvement.
    First get it right on the glass then adjust the DF.
    Whatever
    • CP-1015
      • Nov 2020
      • 317
      It happens most by transport from fixing. Lift the left front corner.
