bizhub c220 error code c-186 (firmare issue?)
  • GabrieleZ
    • Aug 2025
    [Error Code] bizhub c220 error code c-186 (firmare issue?)
    Dear All,
    My bizhub c220 just stopped to work with error code c-186.
    Based on my research in the web it looks like this problem can be solved by re-flash the firmware.
    Unfortunately, it looks like Konika-Minolta do not release this firmware to the users.
    Anyone knows if re-flash the firmware can fix the problem?
    In case, can someone provide me the firmware?
    Thank you in advance
  • copier tech
    • 8172
    Re: bizhub c220 error code c-186 (firmare issue?)
    Originally posted by GabrieleZ
    Dear All,
    We can supply you the firmware should you need it.
    Firmware Update - Printer & Copier Firmware
