C454e ADU clutch no power
  • fishleg
    • Mar 2009
    • 426
    #16
    Re: C454e ADU clutch no power
    Originally posted by allan
    Check if you can see what drives the clutch solenoid on the PRCB if your ICP's are all ok.
    Could be something like a driver IC or a MOSFET that is toast.
    Any easy way to check the MOSFETs with a meter? I guess if its driver IC it's a bin board job.
    • tsbservice
      Field tech
      • 8010
      #17
      Originally posted by fishleg
      Sorry yeah I'm getting the two mixed up definitely the exit clutch...
      Are you sure CL8 (p/n A161M20100) was replaced?
      ...How do you know which ICP is for the clutch? I couldn't find any mention of them in the service manual.
      CTRL+F (IC protector)
      • fishleg
        • Mar 2009
        • 426
        #18
        [ATTACH=CONFIG]47600[/ATTACH]
        100% sure we replaced the whole drive with all the gears, motor and clutch attached brand new from Konica.
        Oooo thanks for that tip .
