Bizhub C221 error code 3925
  • r4roty
    • Jan 2017
    • 8
    Hello All
    While trying to bring out the transfer belt of this copier, I removed the fuser unit however after re installing the removed items and switched on power the copier failed to warm up but threw up a 3925 code. Upon trouble shooting I discovered that one wire in harness by the right side door to the center temp sensor pulled out, after correction copier failed to reset.
    Now the main issue is this: I entered service mode scrolled through the menu couldn't find fuser reset. Maybe there are steps I'm not taking .
    Your help to resolve this will be much appreciated. Thanks
