IT5 image quality Cyan/Magenta "Spots"
  • Eifelaner
    • Jun 2018
    • 3
    Hello comrades
    We have more and more problems with "spots", which are particularly noticeable in halftone printing. The error picture as shown in the appendix, yellow comes through in red print. It is similar with green.
    The spots appear to be 99% of the time on magenta and cyan, which lack color. Although the TCR values all look normal. Do you know the symptoms or maybe even have a solution?
    Kind regards
  • tech51
    • 846
    Re: IT5 image quality Cyan/Magenta "Spots"
    Latest firmware, function version 4.2 or later.
    Service mode, image process adj, page 2, charge control, immediate adjustment, cmyk or k. Start.
    Can be set to auto adjust Which will do adjustment for all colours when main power is switched on.
    Theres a document on Knova about this.
    Hope this helps.
      • 23010
      It looks like magenta developing to me. Try these originals:
      • Eifelaner
        • Jun 2018
        • 3
        tech51
        Thank you Tech51, Firmware should be X4 and function version 4.2
        Do you have a document code for me? i looked for something similar but was not able to find anything specific. Just that it has been implemented with the firmware
        blackcat4866
        I will try these and report back, thank you Blackcat4866
        • Eifelaner
          • Jun 2018
          • 3
          i did play around with the voltages, with no satisfying results.
          in the end i replaced, the developing units DV-313 and drum units DR-313 for cyan and magenta.
          also a new transferbelt unit was needed.
