c224 jam "caution, fuser unit is extremely hot"
  • McCrazy
    • Feb 2020
    • 15
    I've got a c224 and when printing larger jobs a paper jam occurs. Then on the display I'm getting an error that states,"Caution, fuser unit is extremely hot". We replaced the fuser once this started and it continued to throw same error when jamming. Now the machine will not print at all. Anyone seen this?
  • qbert69
    • Mar 2013
    • 1152
    Re: c224 jam "caution, fuser unit is extremely hot"
    It's ALWAYS going to throw the "caution hot fuser" message!!! It's warning you that it's HOTTT!!! DERP!!![emoji2957] Use your Noodle!!! If it's "always jamming", check to make sure the paper medium is within spec!!!...as a pre- fuser loop is formed and temperature ramped up for proper media fusing.
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • qbert69
      • Mar 2013
      • 1152
      Is the paper that's "jamming" glossy, heavy, brochure stock by chance???[emoji848]
      • rrrohan
        • Sep 2011
        • 1977
        Jam code?
        Sent from my Pixel 4 XL using Tapatalk
        • tsbservice
          Field tech
          • 7999
          This message is TOTALLY UNRELATED to problems you may have. This is just warning for enduser(and not only) the fuser area is hot. As others mentioned start with error code and we can work from there.
          • Genotrom
            • Feb 2020
            • 77
            Also, where does the paper get jammed?
