Error paper size bypass on C364e
+ More Options
Posts
  • furius
    • Jan 2018
    • 34
    Good Morning guys
    I have a problem with a C364 not detecting the correct paper size in the bypass tray.
    I tried to completely replace the entire door, and updated the machine firmware ti the lady version,but the problem remains.
    I attach a photo
    Thank you very much
    Inviato dal mio M2002J9G utilizzando Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: Error paper size bypass on C364e
    You need to calibrate the variable resistor that detects the width.
    Its under machine in service mode somewhere. Find the instructions in the manual.
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5795
      what is the problem?
      looks like letter is on the tray.
      did you expect A4? is it set to inch instead of metric?
      am i being forced to extrapolate from incomplete data?
      • tsbservice
        Field tech
        • 7970
        Like allan said there's specific procedure in SM to calibrate bypass.
        • furius
          • Jan 2018
          • 34
          The paper inserted in the tray is in a4 size but the size detected is the one in the photo
          • furius
            • Jan 2018
            • 34
            I did not know about this procedure try to look in the SM and update you thanks
