KM c545e IP not accessible in google for scanning
  • patrickjlc
    • Feb 2015
    • 225
    Hello, i have a C454e that I installed using the latest driver, and it reads the machine IP and installs it no problem, same with all the other computers on the network.
    My problem is trying to setup the scanner, when I put the copiers IP on the google search bar, it comes as not found/ and with the not safe website address.
    My question is could the machine have security setting? We had a 454e and it connects fine thru google and the konica setup page.
    Thanks for your help.
    Sent from my motorola one 5G UW using Tapatalk
  • afterhours
    • Mar 2017
    • 152
    Re: KM c545e IP not accessible in google for scanning
    You should have an option to continue to the website anyways.
    Maybe it says advanced or something like that.
    You can also try a different browser like Firefox.
    Sent from my SM-G981U using Tapatalk
    Im a Loser Baby!!!
    • patrickjlc
      • Feb 2015
      • 225
      Ok, thru chrome it didn't show anything to go advanced. Will try with firefox or windows. Thanks
        • 16406
        You mean like the image below? Your may be a little different. Just click on the advanced button or whatever tab you have and you should be able to connect. See image below:
        • afterhours
          • Mar 2017
          • 152
          Yes
          Im a Loser Baby!!!
          • patrickjlc
            • Feb 2015
            • 225
            [ATTACH=CONFIG]47679[/ATTACH]
            No, i type the Ip, get the little triangle on the searchbar next to the ip numbers and a page not working screen...
            • rrrohan
              • Sep 2011
              • 1977
              Never heard of that model
              Sent from my Pixel 4 XL using Tapatalk
              • patrickjlc
                • Feb 2015
                • 225
                Its a c454e. Typo on the title.
                • lartis.aineias
                  • 78
                  try with another pc or (laptop better) with cross cable!
                  Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
                    • 16406
                    Do you have the copier set on the same network range?
                    • Synthohol
                      Certified Konica Expert
                      • 5846
                      are you typing in the search bar (incorrect) or the address bar? (correct)
                      • patrickjlc
                        • Feb 2015
                        • 225
                        Yes, i had installed a b/w 454e and sold them a color one to upgrade. It connects fine to print, even from my iphone. But can't access it to set up scan.
                        I am going to bring another color machine to test or swap. The b/w had no issues. I was thinking it could be a firewall or anti-virus issue.
                        • patrickjlc
                          • Feb 2015
                          • 225
                          It connects fine. Tried on two computer. Tried with a different ip, vonnected ok. But still had no access to it. Even their IT guy had no answer...
                          • Synthohol
                            • 5846
                            make sure PSWC is turned on and the HDD is set to installed.
                            • emujo2
                              • Mar 2017
                              • 1579
                              Stole my thunder..BTW the PWSC setting is called HTTP server in admin..if this is set to off you will never connect to the web page..E
