Ineo 458e freezes when turned on
  • pinspin
    • Oct 2011
    • 156
    [Misc] Ineo 458e freezes when turned on
    The copier, when turned on, goes through most of the loading stages and at the end freezes for 5-10 minutes. Then it spontaneously continues downloading and works as usual. We performed a firmware update , changed the Main Board, EMMC, HDD, the fuser - it didn't help. We will be grateful for any help. Thanks
  • tsbservice
    Field tech
    • 8020
    Re: Ineo 458e freezes when turned on
    Are some options installed? Or external memory? Remove any if installed PLUS dual scan DF board and try without it.
    • Max
      • Oct 2011
      • 561
      Sounds like its waiting for something to come to a ready state. Then times out and carries on. Any 3rd party hardware/software, licence for something? Refit every connector at the back and disconnect every option.
      • tsbservice
        Field tech
        • 8020
        Good idea. Bizhub Marketplace may acting up.
        • pinspin
          • Oct 2011
          • 156
          It was Dual Scan Image Processing board (DSIPB) .
          Thank you very much for the help
          • copier tech
            • 8174
            Thank you for the update.
