BH 420 the gears ASSY to break fast
  • mosiad
    • 5
    I have a 420 bh
    and every 50,000 sheets should be about to change the gear ASSY
    I do not know what to change!!!!!!
    ASSY go easy.
    why they break?
    the best things are free
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Not sure what you mean. Are you saying that you have a part breaking every 50,000 prints, or that you believe that you have to change a certain part every 50,000 prints.
    • mosiad
      • 5
      device has 700,000 sheets
      last 300,000 sheets have changed 6,7 times the set of all gear from assy.
      • copytechman
        • Nov 2008
        • 949
        Um.. which gear ass'y are you referring to? There are many in that machine!
        Regards!
        A.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Which gears are breaking? Developer box? paper feed?
          • ni311
            • May 2008
            • 658
            I believe it's the gear assy that turns the fusers...
            If it's breaking too often, try putting someone else changing it...
            Konica Minolta Error Codes - Explanations and Solutions
            • harry2007
              • 52
              gear
              i think -is about toner conv gear -anyway-all the plastic gear that are in contact with metal gear must be greased. Put some silicon vaseline .
              Noroc!
              http://copierservicereset.com
              • mosiad
                • 5
                Sorry.
                problem is wiht gears from that fussing ASSY
                • mosiad
                  • 5
                  Noroc!
                  moroc bun!!
                  • harry2007
                    • 52
                    For the best results you must be use in the future the gear for bizhub 500. It's little bit different ,you'll be need for a spacer (4mm), but your's problem will be ended.
                    and don't forget -change regullary oil web unit(200k)
                    • ni311
                      • May 2008
                      • 658
                      Bizhub 500 & 420 are having the same parts manual...
                      • harry2007
                        • 52
                        gear
                        Yes,is true,is almost same parts manual -but just yesterday i was changed this gear and is different like the original gear (on the machine) the pin hole is 4 mm deeper. maybe is a new -modif. model.
                        Unfortunatelly i can't find the bag with parts code for this new gear .
                        • harry2007
                          • 52
                          new gear
                          Description
                          Fuser driver gears do not fit onto the existing fuser drive panel/G assembly (p/n 50GA15070F).
                          Solution
                          CAUSE: The drive panel has been modified and the part number for the fuser gears have been changed.
                          SOLUTION: Refer to attached Bulletin Number 6123 for the correct part number for the specific fuser drive gear.
