konica bizhub 658e
  • Kent
    • Feb 2018
    • 17
    konica bizhub 658e
    random C 9401 codes, it may go days w/o erroring did update firmware, it probaly exhibits itself more as an internal error,, thinking lamp first, otherwise things could be expensive
    • 23010
    Re: konica bizhub 658e
    I've had success on the 808 and 658e with replacing the CCDB. They are the same CCDB for both.
    This was a common error on the 284e, 554e, and 754e, also solved by the CCDB. =^..^=
    • tsbservice
      Field tech
      • 8081
      Only can add that on 754e I replaced CCDB KM have new preventive FW to cope with that error.
      • Max
        • Oct 2011
        • 575
        Firmware can fix if it hasn't gone too far. But sound like it too late.
        • Bix
          • Apr 2018
          • 1421
          For curiosity. What is causing the problem? Overheating? I would like to understand what they did in the firmware to fix this problem
          • tsbservice
            Field tech
            • 8081
            Bix search CSES for TNEU1500266EN
            • Max
              • Oct 2011
              • 575
              Its a voltage issue. Too much to be exact. New fw drops it down quite a bit. But if its gone its gone.
              • B0265
                • Jan 2007
                • 718
                From what fw version is this fix introduced?
                Have a similar problem on a C458
                • Max
                  • Oct 2011
                  • 575
                  Just had a look again on tech bulletin and the fw fix is for the 654e not the 658. Updating fw wouldn't hurt but sounds like ccd is gone.
                  • emujo2
                    • Mar 2017
                    • 1579
                    We had one that after replacing everything related to the code it turned out to be too much light from a nearby window letting in direct sunlight.. Go figure..E
                    • tsbservice
                      Field tech
                      • 8081
                      Lucky me...if I had it this one will kick my bottom for sure. How evil!
                        • 16561
                        I've run into this problem a couple of times. The first time kicked my ass. Also, used to have problems with desktop copier not being level causing void area on one side of the page.
                        • tulintron
                          • Jul 2014
                          • 668
                          This week I updated a C258 and a C658 with the G00-E1 version which gives me the Portuguese language here in Brazil.
                          After update, both printers gave me C-9401
                          • tulintron
                            • Jul 2014
                            • 668
                            The only FW that saved me was the G00-W4.
                            They came back and work well
                              • 23010
                              We've got a couple of bizhub 808's that are printing 250K a month and scanning 500K or more per month. The codes will start at 1.5M scans and become more and more frequent. They automatically reset, so most of the time the enduser doesn't know they are occurring. When it gets to twice/three times a day I'll replace the CCDB and it goes away. These huge scanning volumes kill a CCD quick. =^..^=
