Misaligned Page in ADU (Duplex) on C8000
  • adkw
    • Jan 2021
    • 7
    I'm having an issue with pages going that are going through duplex trigger a misaligned error/jam. It looks like the paper shifts slightly to the left as it goes through the ADU on the bottom side causing it to jam. It happens about 4-5 sheets into a job. All rollers and roller bearings inside the ADU were recently replaced. pages printing singe sided are fine it's only happening on duplex pages. Anyone ever experience this?
  • snoopyed
    • 8
    Re: Misaligned Page in ADU (Duplex) on C8000
    What is the error code?
    從我的iPhone使用Tapatalk 發送
      • 23007
      Jam code?
      • adkw
        • Jan 2021
        • 7
        Jam code?
        It's J-9345. I couldn't find it in the service manual. It says Paper was fed with mis-centering. I can see the paper is physically slanted to the left under the ADU
          • 23007
          Is the first side image properly square, centered? If yes, it happened after the first side was imaged and before the jam location. If no, the skew happened before the page was imaged. =^..^=
          • tsbservice
            Field tech
            • 8009
            Any clutches in ADU? You may want look at them if any.
            • adkw
              • Jan 2021
              • 7
              The first side comes out properly square, but as it flips over it looks like the page shifts. I've tried replacing all the rollers and roller bearings in the ADU as well as the registration roller and the issue hasn't gone away. Had a few Konica techs look at it and they can't seem to figure it out. Could it possibly be a bad clutch? f
                • 23007
                What about the fuser and inverter/exit assembly? A page skewed in the fuser may not identify a jam until further down the paper path. =^..^=
                • adkw
                  • Jan 2021
                  • 7
                  Let me swap out the fuser and I'll update you. I have a spare fuser assembly I can try. The belt and shaft on the exit assembly were recently replaced but I will take another look at it.
                  Could the fuser or exit assembly/inverter be an issue since the jam seems to only happen on a duplex. Single sided copies are perfect it only runs into an issue when we're printing double sided jobs.
                    • 23007
                    Possible, yes.
                    • tsbservice
                      Field tech
                      • 8009
                      Found something maybe similar:
                      Konica Minolta C6000 with J-9451 can't duplex
                      • adkw
                        • Jan 2021
                        • 7
                        The clutches appear to connect to the main body and not to the ADU portion of it. It rollers are above the ADU unit. Clutches seem to be spinning without much resistance and no grinding.
                        • adkw
                          • Jan 2021
                          • 7
                          I tried cleaning the conveyance roller and I was able to print around 10 pages prior to another jam (furthest I've gotten in awhile). The rollers feel a bit smooth and worn out. Going to replace this and the pressure roller on the exit assembly and see if that does the trick.
