C35 scanner
  • wynter17
    • Mar 2019
    • 33
    C35 scanner
    Hello,can the scanner be disabled? Thanks
    Sent from my SM-G980F using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: C35 scanner
    No just fix the belt or ribbon cable.
    Whatever
      • 29936
      Re: C35 scanner
      You should be able to remove the scan icon from the panel
      • tsbservice
        Field tech
        • 7981
        Re: C35 scanner
        Nope.
        Machine won't function as he has scanner error code. He just want to isolate scanner and use it only as a printer.
        • wynter17
          • Mar 2019
          • 33
          Re: C35 scanner
          Nope.
          Yes,exactly
          • M94
            • Jul 2020
            • 158
            Re: C35 scanner
            Yes,exactly
            What about disabling it in the driver? Or just disconnecting it physically?
            • Synthohol
              Certified Konica Expert
              • 5805
              Re: C35 scanner
              Or just fix it?
              That's like asking to have a refrigerator freezer combo but just turn off the freezer part.
              It does not work like that.
              • M94
                • Jul 2020
                • 158
                Re: C35 scanner
                Originally posted by Synthohol
                Or just fix it?
                I don't totally disagree but at the same time repairs can cost, if the client doesn't use it I can see why the 'just turn it off' plan would be appealing.
                • tsbservice
                  Field tech
                  • 7981
                  Re: C35 scanner
                  The reason for this is called machine initialization process. Every machine I know has it. If you simply disconnect scanner from main board it won't initialize. I may check service manual but strongly believe that allan knows the answer.
                  • M94
                    • Jul 2020
                    • 158
                    Re: C35 scanner
                    Just to double check myself I went and disconnected the ADF on my Taskalfa 3551ci and it turned on just fine... Then I realized noone ever said ADF and my assumptions are shameful
                    • wynter17
                      • Mar 2019
                      • 33
                      Re: C35 scanner
                      Or just fix it?
                      The thing is that we already replaced the scanner lamp 2 times in 6 months,now will be the third time,the printer itself is in good condition thats why i wanted a way to disable it.
                      • tsbservice
                        Field tech
                        • 7981
                        Re: C35 scanner
                        M94 not at all as far as I'm concerned
                        • tsbservice
                          Field tech
                          • 7981
                          Re: C35 scanner
                          Did you tried what allan suggested?
                          • allan
                            RTFM!!
                            • 5462
                            Re: C35 scanner
                            Look at the bottom of the ribbon cable for wear.
                            Been scraping of the isolation and soldering the tracks.
                            Then there could be discoloration on the reference patch.
                            Also I use to lift the front of the scanner rails with shims to bring the scanner closer to the glass with about 1mm that helped a lot.
                            Would recommend trying that. Shim it with paper on the far side its got a shaft and the near side an angle rail. Just raise that a little.
                            Forgot about that.
                            Lucky i don't have to struggle with these machines any more.
                            Sure they should have released firmware by now that will stop the lamp from running all the time...
                            Whatever
