72-87 FS-534 Folding unit
  • Genotrom
    • Feb 2020
    • 77
    I recently retired an FS-534 with a folding unit. I don't know its history but it seems in good condition. No jams in the two output trays but only when I try to fold.
    The paper is rolled up before exiting the book exit. As if it were stuck. Some idea?
  • allan
    RTFM!!
    • 5462
    Re: 72-87 FS-534 Folding unit
    Take a picture of the jam that could help.
    Go check the theory of operation on that unit.
    Jig the door take of covers if you need to, take a peek if anything is viable.
    Its got a "knife" and 2 rollers that does the business.
    Sure its something simple.
    Whatever
    • WLIT
      • Jan 2020
      • 40
      Is the fold off center by about 2.75 inches?
      • Genotrom
        • Feb 2020
        • 77
        Thanks! The card stops at this point. There is no way to get it through. There is something that is not clear to me
        • WLIT
          • Jan 2020
          • 40
          It appears as if there is something blocking the paper path, like a displaced mylar guide, scrap of paper or the folding knife is not at home. You say that the "card" stops where you circled in the pic. Do you mean cardstock is the media being used? If so, how does the folder do using plain paper? And if it is cardstock is it within specs for that finisher?
          • Bix
            • Apr 2018
            • 1421
            Hi, try to check if the cartridge is mounted correctly
            • Genotrom
              • Feb 2020
              • 77
              it's plain 90g paper. I recovered this finisher from a printer graveyard and there is a good chance there is some piece missing or something is blocking the paper.
              But without taking it apart, we won't be able to know. The other trays and stapling work, only the third tray with folding is the problem. So, I will try to disconnect when the printer is not needed. We update soon
              • allan
                RTFM!!
                • 5462
                [ATTACH=CONFIG]47913[/ATTACH]
                [ATTACH=CONFIG]47914[/ATTACH]
                Sorry sir apologies for some confusion. Tried to say take a pic/video of the jammed paper.
                of the physical
                Whatever
                • allan
                  RTFM!!
                  • 5462
                  Don't think i should go all the way thru there. Think it stops there to get stapled and then reverse back again.
                  Whatever
                  • Genotrom
                    • Feb 2020
                    • 77
                    thanks everyone for the support. I managed to get a video sent to me:
                    In the video it is not seen but the paper comes out of the second tray and then returns for folding. At this moment it jams.
                      Then check the gates/plates that divert the paper. Selinoids could come into play.
                      • femaster
                        • May 2011
                        • 1526
                        Where that paper is being pulled from, there should never have paper there. It should be going down into the slot that is on the right side of those 4 gray rollers on the top of the folding unit, between the metal and black plastic guide.
                        If by paper coming "out of the second tray" you mean the stacking tray, where paper gets stapled during a staple job, then the paper is taking the wrong path. The gate that is supposed to direct the paper into the folding unit is not working as it should.
