Konica Minolta Bizhub C454 falsely saying low Cyan but it's full & very light prints_
  • patterson70
    • May 2010
    • 605
    Hello, this is a re-post of a few days ago that I had to re-create due to ending my title with the word "Print". It appears if you do that you cannot reply to anyone offering help because you get the print-only version with no place to reply.
    So, the problem with the machine is very light prints even with a full cyan toner. Thank you rrrohan and Copier Tech for your suggestions. Also Copier Tech for the attachment.
    I have to admit I do not understand the attachment diagram too well. I could not get the front panel off. I took out the screws but it was not coming out.
    Am I missing something? I am wondering how often the toner hopper(s) go bad?
    Machine has 458K on it and I am a new tech on it without any prior service history. I am wondering if the user reset the drum and DV replacement warnings and what I am dealing with is just an old Drum and DV unit(s)?
    Lastly, the Cyan DV Unit looked empty when you look into the tube that feeds it toner. Is that supposed to be full?
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica Minolta Bizhub C454 falsely saying low Cyan but it's full & very light pri
    If you think the dev is the issue you can check the Toner to Carrier ratio in service mode
    should be about 6%
    If the ratio is low you can attempt to add toner via service mode
    I suspect the drum has shorted on the dev causing it to suck dev and Id be replacing both drum and dev at same time.
    I recall someone once pointing out that if dev was sucked the WTB will be heavier than normal
    • copier tech
      • 8236
      Its about 12 screws, the front cover & the small inner cover (3 screws) or read the service manual.
      • Max
        • Oct 2011
        • 575
        If toner hopper is empty check the bottle is turning through manual toner supply. If turning OK then it's probably hopper issue. Is the mag roller evenly covered or patchy? If patchy try replacing dev unit and drum at the same time.
        • patterson70
          • May 2010
          • 605
          Thanks to all. Could you direct me as to how activate the manual toner supply? I know on the Ricohs but not sure on KMs. I know how to get into Service Mode but from there cannot find it.
          • tsbservice
            Field tech
            • 8077
            Did you check what copier tech adviced? You will also eventually need to actually read this service manual because it's going a bit complicated if you don't have experience on Konicas.
              this isn't something you want to stumble into blindly...
              you have been told to Read The Fucking Manual ... best advice you could heed.
              • copier tech
                • 8236
                As harsh as this reply is, this will be your best bet rather than wait for a reply, especially if you are in a different time zone.
                  Yes I can be 'harsh ' but reality has to set in at sometime
                  We have all have that time when we're just beat.
                  Some come to know that.. others just can't.
                  • patterson70
                    • May 2010
                    • 605
                    My apologies. I don't have a service manual and many times service manuals leave a lot of critical info out. All about protecting Tech's jobs. I get that. I am an independent and I have seen other independents treated this way on other forums as well. We are the competition I know.
                    Looks like you have better luck if you are a Konica Trained Tech to ask questions on this Forum. Thanks for heading me in the right direction though.
                    • CP-1015
                      • Nov 2020
                      • 326
                      • copier tech
                        • 8236
                        Here is the service manual so have a read.
                        https://mega.nz/file/lQ0kWZTY#cCnN-5...fTWIu4DPiD8MgQ
                        Search for manual add toner. Now see my previous post, take off the inner front cover & remove the white cap, cheat the front door, run manual toner add check if the cyan hopper is driving, clean that white cap before you fit it back can get clogged with compacted toner.
                        • REGSIS
                          • May 2016
                          • 440
                          First thing you should do is to take out cyan developing unit and visualy check toner brush on magnet roller.
                          If it is evenly covered than youa are dealing with toner hopper issue. Mainly that is sorted out with replacement of front white bushings (modified).
                          Most of cyan issues goes to overlife drum sparking and depleting developer, or charge corona dusted with cyan toner.
                          On high meter machines it is recommended to set TCR value for Cyan to -1 under Image process adjustment.
                          Clean drum unit or replace.
                          Replace devC if there's no brus on magnet roller.
                          • patterson70
                            • May 2010
                            • 605
                            Many thanks to all! I will be getting by the account again soon and will report back. This forum is "most excellent"!
                            • patterson70
                              • May 2010
                              • 605
                              I should have also mentioned that the display shows to add cyan toner even though the toner is a full genuine KM.
