Konica Minolta bizhub C258 image quality problem
  • Ihar
    • Nov 2020
    • 17
    I have Konica Minolta bizhub C258 with image quality problem (some colored stripes on the fill) - see on foto.
    Total pages printing count is 229k.
    what do you think - what is the problem of image quality?
    How can i see the drum units count?
  • Bix
    • Apr 2018
    • 1421
    Re: Konica Minolta bizhub C258 image quality problem
    With that counter, at least once you should have changed all the drums. It really depends on if you have printed a lot of color.
    The signs do not seem continuous, it could also be the transfer belt.
    • tsbservice
      Field tech
      • 8030
      If you have manual go and read there about Fusing Transport Speed setting adjustment then you can experiment a bit with changing the settings.
        • 23010
        +1 on the primary transfer belt. I saw a similar anomaly on a bizhub 808 ... light gem-like quadrilateral shapes ... no discernible repetitive pattern, and on this machine was 200% of life on the transfer belt assy. =^..^=
        • allan
          RTFM!!
          • 5462
          Make sure the laser slit glasses are clean. Print CMYK half-tone at 127 and post that. If the lines match up on all four prints the transfer belt could be toast. The transfer belts can fail way before yield if a lot of card stock goes thru the machine. See failures from around 100K.
          If you don't have a manual get one.
          Whatever
          • Ihar
            • Nov 2020
            • 17
            The laser slit glasses are clean - I cleaned it with brush on the back side of the front door.
            I think the problem is with C and M Drum Unit (not with transfer belt, because black and yellow test pages look good).
            • allan
              RTFM!!
              • 5462
              At gradient 255 the color almost always looks great. Set it to around 125 then the detail will show a lot better.
              Whatever
                • 23010
                I disagree on the drums.
                There are four unique primary charge rollers in the primary transfer belt unit. One for each color CMYK. =^..^=
                  • 16450
                  I was examining the transfer belt for a Kyocera the other day and I noticed that it has 4 primary charge rollers. I assumed that is for the purpose of charging the upper length of the belt. It appears that would be incorrect. Let me take a guess.
                  The individual colors need a different charge on the belt because of the different properties of each color toner? Just a guess.
                  • Ihar
                    • Nov 2020
                    • 17
                    I don't have service manual for this model and cann't see Drum Unit count life status. Anybody know how to see it?
                    The new one (Drum unit A7U40TD DR-313 YMC) has only 55k pages (or it's mine diller mistake)?
                    • konicavod
                      • Feb 2020
                      • 27
                      you can use web interface for it.
                        • 23010
                        Sorry, no. Each primary transfer roller transfers the single color image CMYK from each drum to the primary transfer belt. There is a mechanism to lift the CMY primary transfer rollers away from the drum when black only images are being made. On every machine I've ever worked on the (4) primary rollers are identical. There are other rollers called "facing rollers" that tension the belt.
                        • Ihar
                          • Nov 2020
                          • 17
                          Replacing the Drum Unit gave a result. Left one is before replacing - right one is after.
                          • fornerm
                            • 82
                            Hi,this is interesting, i have the exact same problem with a 308 since yesterday.After I have done all the standard things, even change ITB, DV Units looking good, the following happens when changing the drum ..... see pictures ......
                            Before with stripes and dots, then still dots, at the moment I can't get any further .....
                            And another interssting thing, the old Drums looking good as well,
                            stripes also go partly diagonally
                            There have been reports of a blown HV plastic block near the drive. Can that be?
                            Any Idea ?
                            mfg Markus
                            • CP-1015
                              • Nov 2020
                              • 323
                              bit switch 227 hex 00
