Bizhub C554e
  • Jakobi
    • Mar 2019
    • 16
    [Error Code] Bizhub C554e
    Did anybody encounter this error code? C-FD60 (suppose it is an abort code). After reboot (himself) it continues to work. (for how long?)
    So i'm going to check/change HDD, memory module.( my guess).
    And yes i've read the manual. no luck there.
    Any opinion about this?
    Thank you.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub C554e
    try this thread C364e issue 2 sided adf. Has dual scanner. CFD60
    • Jakobi
      • Mar 2019
      • 16
      Re: Bizhub C554e
      Visited the copier and check HDD and memory modules: everything seems to be ok.
      But. from time to time (can't find a patten) the back of the print is striped.
      like above
      i suspect the cable (like rrrohan sugested )
      i will deal whith that tomorrow: changing whole DADF from another machine, so i can eliminate any problem from this part.
      keep you posted.
      • Jakobi
        • Mar 2019
        • 16
        Re: Bizhub C554e
        Changed DADF (DF-701) whith one from another working machine.
        Changed dual scan board (the board that black video connector is inserted)
        Works for a few thousan copies, than again that damn background on back of the page.
        no hint no nothing....
        • tsbservice
          Field tech
          • 8053
          Re: Bizhub C554e
          Then you may have to bite the bullet and replace MFPB.
            • 8202
            Re: Bizhub C554e
            Thank you.
            Most likely firmware is corrupt simply update.
            Firmware Update - Printer & Copier Firmware
            • Bix
              • Apr 2018
              • 1421
              Re: Bizhub C554e
              It could be RAM too
              • Jakobi
                • Mar 2019
                • 16
                Re: Bizhub C554e
                yes. i have that uncomfortable feeling. but i want to try changing that flat cable who connect to the MFPB too. i want to see if that will be the problem.
                Keep posted.
                • Jakobi
                  • Mar 2019
                  • 16
                  Re: Bizhub C554e
                  This is a good ideea. i'll try this next time.
                  • Jakobi
                    • Mar 2019
                    • 16
                    Re: Bizhub C554e
                    Originally posted by Bix
                    It could be RAM too
                    Ive change it already. twice. no luck. and The HDD whith cables ( once )
                    so like tbservice said i've bite A bullet...
                    • Gift
                      • Mar 2011
                      • 2459
                      Re: Bizhub C554e
                      Updateing/Reloading Firmware won't hurt indeed. Are the boards and RAM contacts clean? I had a case where the cooling airflow causes some sticky dust built up at the backside of a controller board leading to image corruption. It's also possible to downgrade a C554e with an ARDF in case the customer plays along with that idea. Had a customer complaining about different scan quality between fron / backside scan - a downgrade was the only solution to assure an even image reproduction
                      • Jakobi
                        • Mar 2019
                        • 16
                        Re: Bizhub C554e
                        I've clean the dual scan board whith pressure air until looks OK. ( not quite dusty but let's do things by the book ). RAM modules, air + clean the contacts whith eraser.
                        Still not changed comm. flat cable between this board and MFPB; did not updated firmware.
                        After a long talk whith operator, one thing may be relevant: problem seem to be at jobs whith motre than let's say 10 pages.
                        Scan/print/copy joobs whith let's say 2-3 pages they are OK.
                        And it is not a temperature difference problem: cold at start-up and hotter after a hour of work. (not quite an constant temperature room).
                        • Bix
                          • Apr 2018
                          • 1421
                          Re: Bizhub C554e
                          How cold is it? The polygons of the laser unit may be blocked or obstructed
                          • Jakobi
                            • Mar 2019
                            • 16
                            Re: Bizhub C554e
                            It is not SO cold. And if I have a laser unit problem then all prints must have that background/stripes/whatever. But in my case it will appear ONLY on second side of the page, ONLY on DADF copy, from time to time; I have not a pattern yet.
                              • 8202
                              Re: Bizhub C554e
                              Why did you not update the firmware? this should be the FIRST thing you try before replacing ANY boards.
