Konica Minolta C368 Color Print Restriction
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C368 Color Print Restriction
    Hi All
    Is there any easiest way to restrict Color prints for all the users (There are approx. 13 users) without login. They only should be able to print black.
    And Manager can only print color.
    Kindly advise
    Thanks for your help
  • tulintron
    • Jul 2014
    • 668
    Re: Konica Minolta C368 Color Print Restriction
    Choose the black option as default and hide the function by disabling dipsw
    • tsbservice
      Field tech
      • 8080
      There is mono version of print driver.
        • 23010
        Leave me to state the obvious: use logins.
        • mearmi
          • Oct 2010
          • 350
          Best and simple way.
          Many Thanks
          • emujo2
            • Mar 2017
            • 1579
            The B&W driver is a good idea, but you say the manager needs to print in color, so now you need 2 drivers..My advice would be to turn on user authenticaiton, allow the public user and give it rights to copy/print B&W, restrict color. Create on account and give mgr code to allow printing in color where needed..Without some form of authentication you leave the copier wide open for anyone with a small amount of knowledge to find a color driver and use it to print in color. Users would have seemless B&W printing (even if they choose color it will be processed B&W), walkup users cannot select color, and the one person that needs to print/copy in color can as needed. 1 driver to rule them all. E
            • Firmaware
              • 30
              I would use also user authentification.
              Gesendet von meinem SM-G980F mit Tapatalk
              • mearmi
                • Oct 2010
                • 350
                Nice.
                Thanks a lot
                • kopasz
                  • Feb 2018
                  • 7
                  Which dipsw to disabling the function ?
