C2070 CYAN drums keep failing....
  • methogod
    • Dec 2008
    • 919
    Anyone run into this? same drums on 3070 last over life....
    Two failed in less then 6 months at 30% life.
  • tsbservice
    Field tech
    • 7999
    Re: C2070 CYAN drums keep failing....
    Same exact batch of drums on 2070 and 3070? Maybe bad batch from KM.
    • WLIT
      • Jan 2020
      • 40
      What do you mean by "failing" ? Are you seeing a failure of the drum wiper blade? Or just that the drums are not going their life by the counters?
        • 23002
        Yeah ... what kind of failure? =^..^=
        • FixitYo
          • Sep 2020
          • 15
          Yes, but I'm experiencing this across all colors if your referring to an image quality issues. Drums fail at 30% - 60%, meaning they develop a slight wear on the drum coating that produces an image quality issue, lead to trail bands mostly noticeable on halftones, would pass on darker density graphics. I'll submit a couple pictures on my next call of the drum and image quality. This has been happening to several of my machines for several years since the DU-105 have been introduced.
          • methogod
            • Dec 2008
            • 919
            Another one bites the dust... 40%
