Bizhub C224e grainy image quality problem
  • Sandoval
    • May 2018
    • 12
    Hello,
    I have the quality problem on my bizhub C224e. Check the photos. There is a grainy image.
    I have already replaced the belt and black drum with brand new ones. Used only original toners. Counters B: 230 000 C:46 000.
    Any suggestions?
    Re: Bizhub C224e grainy image quality problem
    Originally posted by Sandoval
    Hello,
    Any suggestions?
    [ATTACH=CONFIG]48094[/ATTACH][ATTACH=CONFIG]48095[/ATTACH]
    the dev units are being depleted.... you need to replace dev power/frames
    • Sandoval
      • May 2018
      • 12
      All dev units or black only? As the color counter is 46000.
      • allan
        RTFM!!
        • 5462
        Please post half tones at 125 and use test chart prints.
        Could be moisture in developer... But also can be a thousand other things.
        Whatever
          • 23007
          +1 on that. If you were to use an image with separate base colors we could tell which colors are affected ... like this:
          • tsbservice
            Field tech
            • 8009
            Are you a tech or enduser? Do you have manul?
              damn sure can't tell from his SPARSE profile...
              my guess? END USER or maybe a green tech... we covered this problem in Copiers 001.
              • Sandoval
                • May 2018
                • 12
                Hello,
                I'm service technician and I have manual, but never seen such a problem.
                • tsbservice
                  Field tech
                  • 8009
                  Hello,
                  Then where are CMYK halftones or use charts BC provided and post samples.
                  • Bix
                    • Apr 2018
                    • 1421
                    Hello,
                    It could also be a paper problem.
