Hello i need help pls..
  • tarzak911
    • 55
    KONICA MINOLTA BIZHUB B250/350 / 200
    I HAVE AN ABORT CODE 0000999a i cannot fix.. problem seem to appear when printing on the net work. any suggestions pls.
  • DadO
    • Dec 2007
    • 401
    Try whit a new firmware. I only had abort code when my PWB-M was faulty.
    • tarzak911
      • 55
      thnk u tried and did not work problem was faulty ip adress.trust me sounds not real but it was.
      • elton
        i have the same code i have replaced all tthe boards and scanner motor , u say it was the ip adress how can that be my machine has no network card in it
        • copytechman
          • Nov 2008
          • 945
          If its a bizhub 200/250/350 mono machine anything like all of the ones I have it indeed has a network connection, built into upper right hand side of scanner unit basically!
          A.
          • ciuffe
            • Dec 2008
            • 2
            The new firmware solves the problem.
            The following bugs are fixed:
            Print from a CAD software, the machine hangs up and does not print anything
            Abort 0x0000999a when printing specific PDF file via PS driver
            Fax country does not set
            Try
            • Deas
              • May 2008
              • 10
              What "new firmwarw" are we talking about? I have G30-80 but still get the 0x0000999a abort code?!
              (Bizhub 250)
              • moonwalker3778
                • Jun 2008
                • 87
                crosscheck MFBS board.
