C2070 with Fiery ic-313
  • methogod
    • Dec 2008
    • 922
    Scanning? wont scan to FTP, or SMB.
    FTP works from C451 in same location...
    It will store on BOX and SCAN to BOX.
    just cant access...
    I can get to web utilities from Fiery... (remote panel, remote...)
    does it need a 3rd ethernet...like the 951 needed two direct connections... has an unused port, but where do you set the IP?
    never scanned before - it will scan to box.
    Fiery remote scan scans 3 pages then fails.....
    so its talking....
    lost... not my expertise
  • Synthohol
    Certified Konica Expert
    • 5898
    Re: C2070 with Fiery ic-313
    you setup scanning on the main box, the fiery need not be adjusted\configured.
    the fiery should be just a passthrough device if anything.
    just setup regular SMB scanning or email.
    make sure DNS and all that is proper.
    fiery scan is like twain, such a needless pain in the ass.
    • methogod
      • Dec 2008
      • 922
      set DNS in the fiery? or on the NIC setting on the engine on the internal address 100.100.100.1 (FIERY NETWORK2) ---direct connected--- main body nic 100.100.100.101
      • methogod
        • Dec 2008
        • 922
        Tapped out for the night....
        tried everything. now when scanning to FTP just hangs as a reserve job....
        2 network ports on back of main do I need more then just the network and serial/HDMI clone cable from the fiery to engine?
        There is an extra port.
