C2070
  • methogod
    • Dec 2008
    • 922
    C2070
    What causes this type of damage to the ITB?
    old belt was due but not bad.
    Client running a job that is a 3 page set, pg1 color, pg2/3 B&W. So ITB cams after 3 pages....
    Old belt shreaded...
    replaced with new belt, did PM.
    same damage and code C4661) after 10 pages.
    Dropbox - 2070 itb - Simplify your life
    COULD it be the CAMMING of the GREYSCALE TO CYMK --
    can this belt still run?
    do you replace the idler roller because of the scoring?
    • 23010
    Re: C2070
    Is the belt tensioning evenly when you have it fully assembled? I've had a catastrophic failure like this when the installing tech tensioned one side, but not the other. It lasted only a few copies.
    Perhaps unrelated, but I've seen a similar ripple pattern in the belt accompanied by a rip, on a Toshiba 45cpm. Different engine design, you understand, but the waste bottle became packed full at the primary transfer belt cleaning unit. The compacted toner forced the cleaning auger spring up out of the base of the cleaning unit, and it got pulled in between the belt and the cleaning roller. It was a nasty mess to clean up. =^..^=
    • WLIT
      • Jan 2020
      • 40
      Re: C2070
      How old is the ITB cleaning unit? Are both red screws removed to allow blade to contact the belt?
      • methogod
        • Dec 2008
        • 922
        Re: C2070
        New belt, same ripple...
        looks like idle roller is scored up pretty good, going to scotchbright.
        see if it holds.
        New belt, new cleaning unit and idle roller on order.
        Turn off auto calibration, see if if can these few jobs out.
        • allan
          RTFM!!
          • 5462
          Re: C2070
          Could it be that its steering it off to the side pressing the belt over the edge?
          Then the steering sensor is not reacting to stop rotation?
          Changed any of the other TBU parts recently?
          Whatever
          • methogod
            • Dec 2008
            • 922
            Re: C2070
            little guide that you take off the transfer roller ASSY, when you have heavy stock....
            was installed upside down....
            FML..
            cheap lesson....
