High pitch whine from bizhub C308 when printing/copying
  • Konicatech
    • Feb 2016
    • 131
    Hi
    Getting a high pitched whine, its not a squeak but a whine. Almost sounds electrical and sounds like its maybe coming from the fusing area but its not the fuser as I've tried another and same result..
    Anyone had this?
  • tsbservice
    Field tech
    • 8020
    Re: High pitch whine from bizhub C308 when printing/copying
    DC power supply?
      • 16416
      Check each fan individually.
      • emujo2
        • Mar 2017
        • 1579
        do you get the whine when scanning? or just print/copy..E
          • 14812
          Originally posted by Konicatech
          Hi
          Anyone had this?
          https://streamable.com/z6u3gm
          Are you sure the whine isn't coming from the desk next to the copier?
          Does the whine happen only while paper is printing, or does it happen while idle?
          • Konicatech
            • Feb 2016
            • 131
            Only happens when printing
            • Konicatech
              • Feb 2016
              • 131
              Only when printing/copying
              • emujo2
                • Mar 2017
                • 1579
                So you can eliminate everything optics related..Possibly a PH motor? You know, many motors can be operated in test mode..Have you tried to eliminate the motors that are working as expected? E
                • Rewind!
                  Somehow it works....
                  • Jan 2019
                  • 89
                  check and lube your bypass tray clutch and gear (looking at the door on the insdie when its open, its on the left side of the bypass entrance). This gear specifically the one on the metal shaft, is notorious for noise. If this all checks out, I would look at my drums next, Ive had random 8 series drums make noise from the rear bushing.
                  JC
                  • tsbservice
                    Field tech
                    • 8020
                    JC
                    Might be 👍
                    • Bix
                      • Apr 2018
                      • 1421
                      Hi, this sound reminds me of a problem I had with the paper exit unit on a bizhub 458.
                      Here is the video of the noise (much louder in my case)
                      Here is the solution to my problem:
                      Noise bizhub 458
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        high pitch noise from fusing area on c308 series is almost always the fusing drive assembly. It can be the exit clutch or any number of the gears forgotten to be lubricated at their shafts from the factory.
                        (when it isnt the fusing unit or exit itself, i should have said)
                        had it plenty.
                        • blazebusiness
                          SanDiegoCopierRepair.com
                          • 1257
                          had it plenty.
                          That's probably the right advice from EarthKmTech . In my experience - 9 times out of 10 with that noise it's usually the fuser unit or the fuser drive on this series.
