Bizhub C280 Firmware
  • wondernomore3
    • Feb 2021
    • 8
    Hi,
    In need of the latest firmware for the C280. Any help would be hugely appreciated.
    Cheers!
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub C280 Firmware
    Originally posted by wondernomore3
    Hi,
    Cheers!
    https://1drv.ms/u/s!Ah_79nptMOdwgYcGfPdBu50HTXFapQ?e=V5bhWB
    GDR-D1
    • mgakono
      • Feb 2021
      • 9
      Hi
      Can I apply the c280 firmware to two machines bizhub c360.and c220
      Wanted to clear "no animation data " error
      Successfully downloaded to a usb 32 formatted usb drive.
      I can access the sp mode
      Thanks for advice, before I brick anything!
      • rrrohan
        • Sep 2011
        • 1977
        yeah it works on all 3
        If your trying to get rid of the animation data error you will need the "movie data"
        • mgakono
          • Feb 2021
          • 9
          Oh thanks
          so i can get to select "movie data" specifically from the firmware?
          this would be excellent!
          • oluwatope333
            • Dec 2017
            • 9
            kindly help out with this link again, i'll need the firmware too pls
            oluwatope33@gmail.com
            • oluwatope333
              • Dec 2017
              • 9
              Hi rrrohan, please consider me too, i'm in dire need of this firmware at the moment, thanks for the consideration
              oluwatope33@gmail.com, thanks
              • Zesti
                • Jun 2009
                • 308
                check email...
                • oluwatope333
                  • Dec 2017
                  • 9
                  Originally posted by Zesti
                  check email...
                  thanks alot
                  • sergiompnunes
                    • Nov 2021
                    • 5
                    hello guys, will it be possible for someone to send me a link with the latest firmware for the bizbub C280
                    I have a machine with outdated firmware.
                    I need smb support and be able to scan to email office365
                    Thank you very much
                    email: sergiompnunes@gmail.com
                    • Synthohol
                      Certified Konica Expert
                      • 5735
                      Machine too old. There is no firmware to enable current security protocols by Gmail or micro$oft.
                      Your machine is obsolete.
                      Perfect upgrade scenario as nothing can be done about it.
                      No longer supported by konica either.
                      Easiest workaround is to scan to a USB stick and email them from your computer.
                      That machine was officially discontinued and obsolete on 12/2019
                      • sergiompnunes
                        • Nov 2021
                        • 5
                        and when to SMB, is it possible to scan to folder?
                        is the last firmware available for this model, allows you to scan to folder... it's just like for smb1.0 I can scan successfully.
                        I would really like to try to update the firmware to the latest one available for this device
                        thanks
                        • Synthohol
                          • 5735
                          You won't be able to scan to windows 8 or 10. Xp or maybe windows 7 only for smb v1
                          Really best to scan to USB stick or buy a new machine with current capabilities.
                          • sergiompnunes
                            • Nov 2021
                            • 5
                            i can and i have how to configure the scans for smb1.0 cifs 1.0
                            will it be possible to send me the latest firmware available for this machine
                              Loading SMB v1 is NOT recommended.. that is why MS is disabled it.
                              Ransomware can infect the computers attached to the copier.
